41 - 60 of 68 Posts
I cut and put an edge to the plenum divider down about 3/8th of an inch on my oval port eddy rpm ag on my 454 but didn't dyno it but seat of the pants it felt better, that's if the OP is considering a dual plane intake?
There's a Pro Systems HP 1000 in the TC classifieds right now for $650 plus $22 shipping
The Ultra XP carbs have a design flaw in the body which creates turbulence and poor booster signal. The 950 has too large of a venturi at 1.6". I would either go custom from Jmarkaudio, Thumper carbs, or go with a Quick Fuel Q1050AN for an off the shelf carb. But they need some reworking as well such as emulsion, transfer slot restrictors, IFR relocation, etc. Usually $300 range for the work. So then you might as well get a custom billet carb!
A 1.6 venturi is too large for 540 cubic inches?
And why would anyone buy a quick fuel carburetor when a brawler has everything that a quick fuel has other than a price tag that's about 33 percent higher?
Yep or you can buy em right off the shelf with a cut out too if you want .
And to me with 540 cubic inch that sees the track hardly ever how often is hp @6300 coming into play ?
Give me low torque on the street.
Or at the track really .
Allways more than one way to skin a cat
If I hadn't already bought the AED 1000 from another member for about that price that I'm very happy with I'd be all over that Pro Systems HP 1000, if I was the OP I'd be looking into it
Be careful with carburetor spacers. Spacers are a bandaid for induction system flow. They do not provide the same benefit to all combos. My engine ran better with a 1" spacer compared to the $150 tapered 4 hole spacer. Although we normally saw 8-10 hp gain on the circle track motors with the tapered, it lost 4hp to the 1" open on my 548.
Discussion starter · #48 ·
No pcv port so the calibration is going to be way off, also drilled throttle plates. great carb for the money, I'm just wanting something closer from the start.
Reactions: shovelrick
I had to remove the 1" open spacer on my 489 do to hood clearance, race engine/dyno shop owner said I probably lost 20 hp but I like my SS hood :)
Yep
Hunch and trial and error is all I've done .
No track just pants
Here is what I learned with spacers last fall at the track. The dual plane intake did not like any of the tapered spacers at all and the car slowed down 2 tenths but the car went quicker and faster with the 1" open spacer. The Single plane Holley Strip Dominator picked up about .002 with the 1" open spacer. When I put the 2" tapered spacer on the single plane the car picked up 2.5 tenths and 1/2 mph. I learned that both intake styles wanted something different.
Reactions: Aml383
I know what you mean about that big tapered spacer. My friend has one and on his 555 it made a bunch of power. I couldn’t fit it under my hood anyway, but he brought it when I dynoed the 548 and it didn’t have the same gain. We were kinda bummed because we thought it was going to really show something. And that was on similar type engines, his 555 made 860 hp and my 548 made 910. So neither engine was a dog.
Reactions: Aml383
Its not that the 1.6 inches is too big is that it less of a venturi becomes when the one hole is 1.6 inches and the throttle blade 1.75 inches. That is a 90% ratio 1.60 / 1.75. For a venturi to work really well you want to be the 80%-85% ratio so a 1.75 x 80 to 85% is like a 1.40 to 1.50 inch venturi which is what some of the 950s are. It has to do with signal strength at low speeds. The Dominator have like 2 inch blade so there venturi starts at like 1.60 and up.
Ok I'm trying to get this right so I get it right on my own lol
So if I have this correct it's a ratio of about
80 to 85% venturi / throttle blade diameter that is optimal ?
Venturi is a dimmension from where to where ?
Also the booster factors in to signal strength.
An anular booster has a very strong signal.
How would or how does that effect the
Venturi/ throttle blade ratio your talking about?
Then another question which may help the OP as well as me :
Should I be concerned about too much fuel atomization using anular boosters along with a hotter intake? Eg; anular boosters with an Weiland air gap dual plane intake without plenum cut out
The venturi size they give you in carb specs. Its the measurement when you look down the carb and its the smallest part before it goes down to the blades. David Vizard did a great book on carbs and it explains it all including like you mention different boosters. Your carb ventrui look like a nuclear power plant cooling tower wide on top and bottom and narrow in the middle.
I do have the book . I'll dig deeper.
I'm a big mr controversy fan lol
I've got 4 or 5 of his books
I tried a tapered and a 1 inch open and a 2 inch open on a dual plane 200cc aluminum heads isky 270 . Stock 350.
No dyno not slip. 2 inch spacer sure did feel like more torque . Pulled harder and pulled longer on the outside
Did you re-jet the carb? as they can go lean with that much spacer.
Reactions: Aml383
41 - 60 of 68 Posts
