The secondaries on a friends holley 2818-1, which is on a 74 327 with a 65 3844461 aluminum intake, won't open? We did the thing where you tie a twistie to the shaft and see if it gets distorted, it doesn't This carb and intake was used on the 65 corvette with the 327/350hp.
We did the suck test on the diaphram and the shaft will suck up and hold. Don't know what cam he has in there. Appears that the original spring is in the diaphram. Also make sure the gasket seal was good between the diaphram and the main body.
Would there be a problem with not enought vacumn? We did manual connect the secondaries and the car preformed a lot better. Thanks.
