Let me start off with this is the motor that was in the car when I bought it. I am just trying to figure out what I can do to improve the power. So with that said here is what I have:
402 BBC
Performer RPM intake
750 Vac secondary holley
Cam is a XE274 230/236 .552 .555
353049 heads <- have no idea what has been done to them
I also don't know what the compression ratio is.
Transmission is a th350 with a shift kit and a 2800 stall
10 bolt rear end with posi and from what I can tell a 2.56 rear gear? It is a little over 2 1/2 turns on the drive shaft with 1 full rotation of the wheel.
I have played with the timing and air/fuel and the car runs decent but it just lacks the power that I think it should have for being a big block. Besides ditching this motor to build a larger motor what would you change?
I was looking at some old posts about 10 years ago when i had about the same combo you have right now.
looking back I had a 396 10.2 to 1 motor with 2.41 gears th350 tranny and a delta cam 233/239@ .050" with .551" lift. it ran 14.47 @ 98 mph with 2.15 60 ft time in street trim.
with some work - intake, carb timing, rhoads lifters and such the car ran 13.50 @ 107 plus mph with ONLY 2.73 gears.
it appears I had about 180 psi cranking compression at best and worst was 170 psi after I installed the rhoads lifters to help with bottom end torque.
Maybe you could type in "ddeennis" in the search and read my posts from 2003 and 2004 which is detailed to what I did and shows times with changes how I got from 14.47 to 13.50 and gained almost 10 mph trap speed with no real big changes that involved pulling the engine. looked like i might have pulled my heads did some porting and installed shim gasket to boost compression more.
Might be some things there to help you out.
here are a few links to some of those posts back then.
http://www.chevelles.com/forums/showthread.php?t=24848&highlight=
http://www.chevelles.com/forums/showthread.php?t=18179&highlight=
http://www.chevelles.com/forums/showthread.php?t=17888&highlight=
http://www.chevelles.com/forums/showthread.php?t=21414&highlight=
Back in the early 90's my 396 had 7.7 to 1 compression( didn't know that then), 272 crane cam which I believe was
218 @ .050" with like .515" lift, had open chambered heads with rebuilder pistons and they was like .050" down the hole with .040" head gasket ( couple of years down the road I found this all out when my engine was going slower at the track trying to make it go faster with bigger cams, converter, gears, intake and carbs) but stil managed I believe 135 psi cranking compression and I had to push timing around 44-46 total for best results at the track. had cheap small tubed headers headers, stock low rise intake with 1" carb spacer and I think just a 600 cfm holley, stock th350 tranny and single spinner 2.56 rear end and that thing would spin that tire for well over a block long and I stomped anyone I raced back then- of course I knew how to take off without spinning my tire. I finally took that little 396 to the track and it ran 14.80 at 99 mph ( first pass) the best I did that night at the track was 14.40 pushing it hard of the line best i could without to much spinning with a 2.19 60 ft time at 99.xx mph, I was so trying to crack 100 mph, my shift point was 5500 rpms.
Not to shabby for a 3600 lbs camaro with a 396 and 2.56 gears.
maybe see what your cranking compression is, remove all the plugs and wire open the carb and throw a battery charger on and get the reading from each hole.
