AFR 305's don't have header fitment issues. The port is barely raised.
Combo combo combo. I'm probabally not utilizing my AFR's to their potential due to my low 9.4:1 CR. Plus mine are 7 years old now.
I have never run my car in mine shaft conditions.
Although I have been 1.37 in 60ft, never been a 1.32 like Bob does.
I don't think Bob ever went near 134 either.
Combo combo combo....engine, trans and car.
Note mine is a street driven car with a full exh with tailpipes.
Not to get in a debate again. Ron you have a bad arse car but a 69 Nova is several hundred pounds less weight than Bobs Chevelle. A Nova is a light car. A chevelle is a heavy car. The two are comparing apples and oranges. However, comparing a stock AFR and A stock RR on the same engine would be a neat comparison plus the streetability. My car sees 70 mile round trips and never gets above 180. Even with a vic jr and spacer it has great street manners.
I am at 3600lbs with me in it. Bob can tell us what his weighs.
Made into race cars with cages and all that, they aren't much different.
Chevelle has a full whimpy frame, the Nova needs subframe connectors Maybe 100 lbs diff, but it depends. Mine has a full 12 pt mild steel cage.
A straight up comparisson between the two heads on the same short block? You will never see it in a magazine. Perhaps Wolf can comment.
Street manners? No one will ever agree on that. I'll drive mine anywhere, and other than uncomfortable, it has no issues. Great throtte response, smoke the tires at will, in cool weather never gets above 170. Hot weather, never above 200, but I don't have a fan shroud. I also don't have an electric water pump, or electric fans. The street car issue will never be settled.
My car was in good tune when I ran high nines, it needs freshining now, and it has 3.73. Will still go bottom tens. Bob can tell you how much his varies from hot to cold out.
Ron
