Robitussin
Discussion starter · #1 ·
Hi everyone, this is my first post--YESS.
We have a Nomad that is in great shape as far as rust goes, the whole thing is covered in it and we have a 454ci out of a 1974 burban that runs that I would love to put in her and I'll be going over as many posts as I can in this section to do some learnin'. The ultimate goal is to have a GREAT running gas burner, make power from 1,000 rpm to 5,500ish rpm, make some noise, get some kind of economy, and make me happy.
My question is this, what should I look out for? Things like heads, cams, casting numbers, blinkerfluid, etc.
Any help, direction to go in, or just a shopping list of goodies and possibly explinations will be cherrished and implemented in some way. Thanks All
Save
economy gas burner? in a 454? The bone stock 454 should work well with some headers and o/d tranny.
The 57's could take a big block without clearancing the firewall, but the 55 & 56 models needed a bit of massaging. The later 4-door Nomads (58-61) offered the W-motor as an option.
I wonder if our friend is talking about a '68 - '72 Chevelle Nomad wagon?
Where are my manners, welcome Robitussin :waving:
Discussion starter · #5 ·
Thanks all
Hey, thank you guys for the help and the welcome. I understand that the fuel economy will be lower than a rat's belly under a tractor but I at least want to make it between gas stations and at best I'd like to expect 10 or so on a towtruck on a good day.
Save
I used to have a .030, 9:1, 454 in my 66 with a 700R4 and 3.55 gears and with an Edelbrock carb going to Nashville we got around 14 at best, going down a long hill, with a tailwind, while drafting on a semi.
I did not have any luck keeping a 700R4 alive behind my BB. It chewed up parts and spit them out.
I did buy one from Pheonix Performance Transmissions http://www.phoenixtrans.com/ to put in my wagon behind the 408 SB. It has held up very well so far. They built a good one.
Some guys use a 200 4R with good luck.
The overdrive trans will get you closer to your goal. If the short block was in great shape you could add a set of closed chamber heads to bump the compression up. Add a better cam and let her run.
Save
