Googling, I found this. Looking at the specs, I'd say this is it.
3883986 1965-
72 Hyd .460I/.488E .213I/.217E See Note 2
Note 2: 396 325/350hp L-34/L-35, 427 385/390/400hp L-36/L-68, 454
345/360/390hp LS-4/LS-5, good torque/HP
Looks like your right. I found the cam used in a 390/427. Put new lifters on it and never had any trouble.
Found specs here: Don't know if they are correct.
http://www.leverfamilysite.com/imag...ages/PDF_Files/Microsoft Word - Big Block Chevy Engine Parts Identification.pdf
I would bet one of UDHarold's mild VooDoo's would be a better choice.
Some years back, I built an 11:1 302 with pocket ported 461 heads with a good valve job, close quench, and a 929 stock cam. Engine was in a Camaro with 3.31 gears. I couldn't get over what a good street engine that made. It was torquey, got good mileage, ran strong until the lifters pumped up. What I discovered from that experience was the importance of better head flow, when used with short duration cams. Joe Sherman's winning EMC SBC, I think it was 366 CI, used a 224/224 cam, essentially, a 350 HP hydraulic.
Quote:bigjoe1 wrote:
The cam I used was in fact a 224-224 -108--I don't care what the magazine says= I did use the cam in another engine that I built for a friend some years later= The surprising thing was that the HP peak was up at 65-6600 RPM, probably because the heads I used were pretty big for the size of the engine
JOE SHERMAN RACING ENGINES Unquote.
One thing I'm not is "Big Joe"!!! But my experience makes me suggest smaller cams than most. AFR also suggest this approach on their website. If you want a REAL street engine, one that doesn't buck and will pull hyway gears, Duration in the low 220's MAX, and close LDA's, 106-108, (smaller engines) can make for good street performance. Of course, large engines NEED more cam timing. But you need to keep intended usage in mind, and not order your cam from the bottom of the page. Most important is knowing what you want to do with a specific engine. None of this advise applies to max performance engines. Unless your "Big Joe"!!!!
