I have floating pins in the new build. Used 40w oil as assembly lube, but looks like alot of it got pushed out as the pins are slid into the pistons. I put the shorthblk togther, and before installing the pan, I'm wondering if the oil I used is sufficient. I also poured oil on the pins since the motor is upside down. Is this enough? I also used 40w on the valves...wondering if this is sufficent also.
