What is it about the LS engines that makes the power everyone raves about?
i am talking about n/a to keep things on a par with n/ sb & bbc.
I guess I just don’t get it.
Basically they are pistons sliding up and down cylinders…but less displacement than most any SB and less than all BBC.
The heads/manifolds certainly cannot flow like a good BBC…or can they?
I don’t know flow rates on these items but they can't rival a BBC..
And even if they can, so what? How does feeding a small cylinder make big power?
I recognize that the EEC is much more precise than any carbureted engine but can that put an LS on equal an power base with a BBC? Is that where the efficiency and power is hidden away from our SB & BBC mills?
The cams are generally less duration than most use here and wide lobe separation which is opposite the BBC and SB that are seeking power here (very typically 108*).
Can someone explain to me how these produce significant power and fuel economy
( I realize that today’s overdrives take advantage of low rpm motors and that keeping the rpms low saves fuel) but I got to tell you that my 03 vetted will run at 1000 but still pulls strong thru 6000. How do they do that?
What are they doing that gives that kind of a power band?
I just don’t get it!
