this has happened twice now with my 69ss, both times after an extended drive ( 30+ minutes ). I've pulled it into the garage and it has run on for 3-5 seconds after shutting down.
Is this a timing issue or fuel related? Maybe this a dumb question, but i just don't know what causes it or how to attck the problem. The 2 incidents have happened about 6 weeks apart, so there has been trouble free driving in between.
Its likely caused by 1 if not 2 or more of items listed below collectively together causing the dieseling.
* overly retarded base timing.(Often need approx 16-18 deg base timing with even mild aftermarket perf cams)
* no vac adv or running or running it on ported not full int vacuum so no additional timing at idle also retarding timing by a min of 10-12 deg if not more.
* too low of octane fuel for compression/cam combination causing too high of cyl pressure.
For example,GM stated even middle farly mild pre 71 motors like for ex 396-402/325hp-330hp-350hp bbc with 10.25.1 comp had to run on a min of premium 98 octane or higher leaded fuel and not todays non leaded lower octane pump fuel with 10% ethenol added that thse 40+ yr old gen muscle car sbc/bbc motors were never designed to run on in the 1st place!
* motor running a bit hot.
* spark plug heat range too hot.
* excessive lean fuel calibration setup or vacuum leak esp at idle and lower engine speeds just above idle causing higher cyl/engine temps.
* too high of idle speed.
* excssive carbon buildup in combustion chambers increasing compression & combustion chamber temps while also making the excessive carbon buildup in comb chambers turn cherry red creating hot spots that can ignite incomming fuel from carb only setups (not efi) even when power to ign is turned off for no spark at plugs.
Etc!.
Scott
