Hey Jim, People here seem to be confused about what you were talking about. Please confirm that you were talking about plugging the passage way with plugs, and not blocking the head to manifold.
rocky
The confusion
isn't as to
WHERE Jim wanted to block the passage (under the carb
or at the head interface, they are both passages for the exhaust cross-over passage)... The confusion lies in the end result (burnt paint) that is unresolved...
James Larson said:
Is it a good or bad ideal to block off the heat passage on the intake? This would be on a stock 66 396 with the original holley intake. Car is driven mainly from April to October in MN. Not raced. Just driven for pleasure.
The paint on the intake burns off. Thanks.
Jim's original post implied that he wanted to eliminate the paint burning on the intake. He didn't mention performance, overheating, choke activation (April -October driving season or fuel vaporization in the carb, and he didn't specify
where he wanted to block the passage.
I have seen the paint burn near the choke, but NEVER seen it burn up near the carb base...
and after reading about Rocky's mod, Jim asked,
specifically...
James Larson said:
Does this decrease the likelihood that the paint on the intake will burn/discolor? If the heat isn't necessary to make the car run during the time we drive these cars , it sounds like a great way to prevent the carb from warping due to excessive heat
That went unanswered...
Eric stated
Vintage Musclecar said:
James;
As we discussed, block off the heat cross-over under the carb with the plugs. Leave the passages open at the cylinder head to manifold junction, this way the choke will still function normally. Heated air will run through the cross-over UNDER the carb (which is what activates the choke), but there won't be any hot air present under the front of the carb.
If you block off the heat cross-over at the manifold to head junction, it will take forever for the intake to get hot enough for the choke to dis-engage.
So ONLY blocking the passage under the front of the carb will likely do NOTHING to solve Jim's issue with paint burning off the intake...
Rocky's solution helps keep the carb and fuel cooler, but didn't address Jim's "concern" of the paint burning of the intake (at least as far as his initial post)...
Now, none of us know what other aspects were discussed "off-line" between Jim/Rocky/Eric...
IMO, the main issue (the confusion) is, people still do use the "search" function on this site, and this topic is likely to come up again someday... Just want to be sure people know whether the pipe plug modification will stop the burning of the paint... Does it solve the original problem???
Rocky's mod sounds like a great way to try and keep the carb and fuel a little cooler, block off another potential leak point (or eliminate specific gaskets) while still allowing normal choke operation. But it doesn't address the burning of the intake paint...
That's all...
