Weld in a Sump or Modify stock unit with 1/2'' lines
  • Weld in sump
    Votes: 17 77%
  • Modify stock sending unit with 1/2'' lines
    Votes: 5 23%
Weld in a sump or modify stock sending unit?
7.6K views 14 replies 12 participants last post by  Bob Tiley
I have my gas tank out now and just wonder after doing many searches on 1/2'' fuel lines should I buy a robbmcperformance.com sending unit with 1/2'' lines or weld on a sump? I would really like to modify the stock one because there is nothing wrong with it. Just try to add a 1/2'' outlet and a 3/8'' return. I don't know if this can be done, I have not pulled out the unit yet. Just wanting to get some opinions.
Engine will have est 700hp.
This is Robbs Mc Performance unit
Freds Sump
Thanks Fred for letting me use your picture.
#2 ·
I've done both.
You need to consider the needs of the pump that will support the HP you want.
The stock unit can be modded to a 1/2 line. Just drill it out and solder in a bigger line.
Getting a tight enough bend to clear the trunk floor is the problem. The one in the picture may be tight enough.
Just noticed you have a camaro. Mine hit the trunk floor even after I dimpled it.
Needed a bigger hammer but it was starting to get a nice lump when seen from inside the trunk.
#3 ·
I am glad i went with the sump on mine. course i do this kinda fabrication for a living on aircraft, so bending/flaring .5" stainless line was no problems where it might be tough at home. also purging the tank and backfilling with argon for welding safely was another thing you might not be able to do at home so easily. here's a link to my install.
http://www.chevelles.com/forums/showthread.php?t=256632&highlight=1%2F2+fuel+system
#4 ·
I sumped my tank; and wish I hadn't.
I'd have been happier with a bigger tube going into the stock sender.
#5 ·
why were you not happy with it?
#6 ·
1. Safety. The sump can rip off in a fairly minor collision; or get bashed on the concrete if the car goes up a steep ramp.
2. Mine is home-made; and one of the fittings leak.
Either way, fuel leaks aren't fun.
#14 ·
Thanks for being realistic about this. I thought the same thing before I got to your post. Sure, a rear ender may damage your take. But elbows will fracture off long before an unmodified tank will rupture. Lots of liability hanging out there... Be careful!
#7 ·
I did a sump, but it was on a new tank so it was much easier. Competition products offeres 1/2 or 3/8, but not a combo. Would need an adapter to run 3/8 return back in-maybe just the smaller fitting on end of line.
I have a 70 chevelle,originally a 307 car what size would the factory fuel line be?
#9 ·
If it's a street oriented car go with the stock sending unit design.
For a fast street/race do the sump or save your money and just buy a cell. It can actually be mounted in the trunk.
Some people like seeing all the sump, lines, filters and pump hanging under the car, but I think it looks cheap, sort of a lackluster design.
-Bobby-
