The 360 hp and 350 hp 396 are practically the same engine from 1966-67.
The 350/360 hp 396's -and- 385/390/400 hp 427's -and- 270/365/360/390 hp 454's ... all used the same cam.
265/325hp 396's -and- 240/300/310/330hp 402's -and- 335hp/427's -and- 235/245/275/345hp LS-4 454's
......... had the baby cam with .398 lift.
Yes 350 and 360 hp 396's had the same cam specs as the 385, 390, and 400 hp 427's. Also the LS5 454's.
I agree, it appears, some 1965-69 396/427 low-horsepower engines used this type cam.
Camshaft number = #3874872
Camshaft Intake duration @ .050" == 196°
Camshaft Exhaust duration @ .050" = 196°
Camshaft lift - Intake == 0.398"
Camshaft lift - Exhaust = 0.398"
@ 114° LSA
__________________________________________
I believe these are the correct camshaft specs, for a 1970 Chevrolet 454 w/LS4.
Camshaft number = #3963544
Camshaft Intake duration @ .050" == 192°
Camshaft Exhaust duration @ .050" = 203°
Camshaft lift - Exhaust = 0.430"
@ 111° LSA
1970 Chevrolet 454 w/LS4 engine.
C.R. = 10.25:1
Horsepower = 345 @ 4400
Torque = 500 @ 3000
I've seen these cam specs listed for the 1973 Corvette 454 w/LS4 engine.
Camshaft number = #353040
Camshaft Intake duration @ .050" == 210°
Camshaft Exhaust duration @ .050" = 213°
@ 113° LSA
C.R. = 8.25:1
Horsepower = 275 @ 4400
Torque = 395 @ 2800
I believe these are the correct camshaft specs, for a 1970 Chevrolet 454 w/LS5.
The duration figures, which are taken at .008-inch lift are 268° int./ 274° exh.
Camshaft number = #3883986
Camshaft Intake duration @ .050" == 214°
Camshaft Exhaust duration @ .050" = 218°
Camshaft lift - Intake == 0.461"
Camshaft lift - Exhaust = 0.480"
@ 115° LSA
1970 Chevrolet 454 w/LS5 engine.
C.R. = 10.25:1
Horsepower = 360 @ 5400
Torque = 500 @ 3200
1970 Chevrolet 402 w/L34 engine.
C.R. = 10.25:1
Horsepower = 350 @ 5200
Torque = 415 @ 3400
I believe these are the correct camshaft specs, for a 1970 Chevrolet 454 w/LS6.
Camshaft number = #3863148
Camshaft Intake duration @ .050" == 242°
Camshaft Exhaust duration @ .050" = 242°
Camshaft lift - Intake == 0.520"
Camshaft lift - Exhaust = 0.520"
@ 114° LSA
1970 Chevrolet 454 w/LS6 engine.
C.R. = 11.25:1
Horsepower = 450 @ 5600
Torque = 500 @ 3600
1970 Chevrolet 402 w/L78 engine.
C.R. = 11.25:1
Horsepower = 375 @ 5600
Torque = 415 @ 3600
Now, everyone will know.. The 1970 LS6 #291's were the last square port closed chamber heads produced.
They're easy to spot by the casting mark on the front of the head. A raised 1/2 oval right at the front casting seam.
They are very prominent and can be spotted standing 10 feet away from the car. :thumbsup:
The #291's were the last Closed Chamber Head, and the only heads used on the production LS6's,
#990's were service replacement and used on some crate LS6's.
As for the bare block itself, the two are similar with the 1971 block having a tall distributor tower where the 1972 and later blocks have a short distributor tower boss in the intake area.
1972 was also the last year the 454 had an LS5 RPO code, later 454s were RPO LS4.
FWIW, the short block assemblies also differed.
The LS5 had a compression ratio of 9.00:1 where the LS4 dropped to 8.25:1 and had a milder camshaft, .2741/.2824 I/E to the LS4s .2588 on both intake and exhaust. So it's not just the heads, carburetion and other minor items that accounted for the change. 1972 also saw hp ratings change from gross hp to net hp.
That's one big reason you see a drop from the 365hp LS5 in 1971 to the 270hp LS5 in 1972.
the 1972 402/LS3 : originally came from the factory w/cast iron crankshaft & cast pistons, open chamber oval port heads, hydraulic lifter camshaft, Q-Jet carburetor w/low-rise intake manifold.
In 1972 w/8.5:1 compression and dual exhaust = 240 net horsepower & and in 1971 gross hp = 300 hp.
"Gross HP" ratings were used until 1971 = the engines output on an engine stand, w/no fan belt or exhaust manifolds.
"SAE net HP" ratings started being used in 1972 = usually the engines output as installed in a vehicle w/acessories installed, (fan belt) & exhaust systems.
Just like the camshaft is the "brain" of the engine, ....... The torque converter is the "brain" of the drivetrain.
... a stock torque converter has about 1,500 -1,600 RPM stall speed ...
http://www.corvettefever.com/techarticles/153_0312_454_cam_profile_testing/viewall.html
