Nothing at all...No blinking, no solid lights, nothing on the dash....Its almost like I've lost voltage. I've tested the wires before and had 12v....I need to recheck to see if it is in fact a voltage issue. I cant remember if the pink or purple wire has the voltage.
Normally a "standard" flasher would show 12V on each terminal if plugged in. When the actual turn signals would be activated, and the ignition was in the run position, the front and rear signal bulbs would then be creating an amperage draw which then the flasher senses and then due to it's design would open up a set of contacts in the flasher and stop the flow of power to the turn signal lights and then after a short break, the flashers contact would then close back up and then again, the lights would come back on. Once closed again, the lights would be drawing power and then the flashers contacts would open back up once again. This cycle repeats itself over and over again until the ignition is turned off and/or the signal switch is turned off. Think of the old school flashers as being something like an automatically resetting circuit breaker.
The old school "standard" flasher was designed for so many lights and a particular amperage draw and would flash on and off so many times per minute. Add more bulbs and the flasher would click on and off quicker and then if not enough lights were attached, the flasher may never break the connection to flash th lights.
Today, you have LED lights and specialized flasher and they have to play together nicely with each other or things do not work as they should.
Jim
