What are you using to protect the block cam thrust area on your BBC with a solid roller cam?
Torrington Bearing
Hard steel thrust washer
Nothing
Torrington Bearing
Nothing
isn't the big core plug in the back of the block supposed to control the rearward travel of the cam?
over the years, GM built millions of V8 (and V6 and I4 and I6) engines over the years that didn't have any sort of thrust bearing or bushing behind the cam gear.
Not all of them. Like I said, I had a friend that had to use a torrington bearing to stop the cam gear from chewing the block. IMO, it's cheap insurance,especially if you use the brass washer(no needles to give out). Oh, a solid button isn't a bad idea either. Had a roller button spit rollers out, luckily none got anywhere.flat tappet cams push the cam backwards without bearings or washers in there, and they can go for 200,000 miles without any problems.
