I have a 67 chevelle with a 355, vortec heads, 750 speed demon carb, a MSD 6AL ignition, Comp cams extreme energy 268 with 1.6 roller tip rocker arms. Edlebrock RMP airgap intake, and flat top pistons approx 10:1 compression. The problem: when I hit the gas the car basically dies out, however, if I leave off of the throttle it corrects itself. If I have the car at 3000rpm and hit the throttle hard it will die out completely. If I ease into the throttle I don't have a problem. I dont' think it's in the carb because I had a 600 Edlebrock carb and it did the same thing. Timing is set at 12deg inital and 32deg total @ 2500 rpm. Thanks ahead for any suggestion
