Hey after 35+ dyno passes and a couple issues I was going to send out my engine to get intake work and figure out why this thing keeps eating #2 T&D shaft rocker. I was getting ready to get it sent out and figured what the heck ill pull the #2 to check it out after seeing the isky ezx roll thread and that it burnt a piston. So I pulled the plug and found this. 4.310 bore doesnt look like a crack but will have the block checked to see if it cracked.
No I am not blaming any of them. I have had issues with the adjusting nut coming loose on my #2 rocker. I was curious if that looked like detonation. The block was dynoed several times I tightened the rocker adjuster to the 20ft.lbs T&D said to and my isky ezx rollers are perfectly fine. I read the post from Rat540 and saw that it burnt GuysMonte pistons. In no way am I blaming the parts I used. I am just seeking answers I will have the block checked just figured someone on this forum with a lot more experience then me thinks this was caused by detonation.
None of the dyno slips showed that cylinder ever go lean. so I am curious why my luck is just crap lately.
But I am sorry for you assuming something I was not doing. I was just curious if the block was salvageable and if its worth it to sleeve to keep my 4.310 pistons or just go bigger.
