Hi all,
I'm testing for push rod length on a gen 1 350 with Vortec heads and retrofit hydraulic roller cam and lifters. I've read in a couple places that you can substitute a solid lifter so that you don't get a false reading due to the hydraulic lifter compressing as you're tightening down the rocker. Is that true? What kind of lifter do I use? I already replaced the springs with weak test springs. Might that be enough to get a good reading?
Also, if I want to use push rods that aren't a custom size, how much in thousands can I move up or down in length without compromising too much on performance?
Thanks in advance for any advice,
Scott
Scott
