I am at such a complete loss right now. When I accelerate very slowly without much load on the engine Im fine. If I give it any real gas, or accelerate when in 4th gear, I get a bogging, almost feels like detonation. I've replaced the cap,rotor, wires, fuel pump, fuel pressure regulator, changed the springs and jets in the carb, checked the float level,changed the timing both high and low, re-wired the fuel pump to include a relay, and still the problem is there. WTF is happening? Like I said it idles fine, accelerates very slowly fine, and even cruises fine no matter what the RPM. The plugs look perfect, the exhaust smells normal/rich, and fuel pressure is a steady 6psi any time I pull over and pop the hood to check. Ideas???
