I have a 70 Chevelle. I changed out the dash and guage cluster with idiot lights. I bought a harness for a 70 SS on ebay.
I am a pretty good mechanic but wiring just drives me nuts.
I have been reading some of the previous posts and have changed the ground wires to: Longest one to ebrake, second to dash frame and third to back of the speedometer. No help. I changed the printed circuit with one that wasn't broken. I made sure the light bulbs all worked. I made sure the headlight switch ground strap was hooked up right.
The speedometer lights work good and bright and will dim ok. The gen outer ring lights up and the light switch outer ring lights up. I don't have lights at the heater control, nor glove box. I don't have the cig. lighter hooked up as I don't allow anyone smoking in the car. (could that cause a problem? Not having that circuit hooked up.) I'm using AutoMeter temp, volts, and oil guages. I don't know how to hook up the gen so it will light when the key is turned on. Same on the temp and oil lights. All 3, temp, oil, gen should light up when the key is turned on, right? My turn signals work but the light on the guage cluster doesn't.
I remember reading one of the posts something about a 12 pin check but can't find the post now.
As you see, I have quite a problem and hope someone out there will be able to put me in the right direction. Gotta get this thing running, Rt 66 Rendeveous is just around the corner. Thanks
Jim
Jim
