This requires a little patience and time, but it has worked for me . Take a small drill bit, maybe 1/16" or 1/8". Drill into the broke bolt. Then progressively use the next size larger bit. Slow steady drilling will get most of the bolt out, then chase remaining metal out with WD 40 or PB Blaster. A slightly smaller bolt may help in removing last bits of metal. All your really doing is making the bolt weaker by removing all or most of its guts. Slow, but keep at it. It works. Give it a try...............:thumbsup:
