Ok so I had a 383 built by a friend who is an engine builder and my rear main seal is leaking for the second time. Im almost 100% its that because ive checked all the usual spots that it could be coming from and nothing just oil coming strait down the back of the pan and some oil on the inner starter bolt. The pan is a moroso not sure if they have poor fitting pans or not but I laid it on the block and it was pretty flat so not sure if I should try another brand or not??? The first time around we used fel-pro second time fel-pro rubber one piece gasket and both had small leaks. Can to much oil pressure cause this??Can it be the seal on top of the crank and I need to change that this time? Can anyone recommend an install tip or a pan choice?
