Hey guys, I have zz383 , 750 DP, Mallory unilite, MSD 6A
Initial timing 19BTC
Idle ~950 RPM
The car runs good at 950 RPM with the manual transmission, but always runs on or diesels (I guess you would call it) after I turn the key off. I’ve even tried backing off the timing retarding it about 2°. But it doesn’t help I can set the idle back down to about 600 RPM , then it shuts off with the key like it should, but I don’t get the throttle response off idle and the clutch doesn’t act as good as when the idle is set at 950 RPM, and it smells better with the higher idle speed.
My question is - how do I keep my car from running on after I turn it off with my idle at 950 RPM. (Very annoying and embarrassing)
TIA
Idle ~950 RPM
TIA
