I'm working on a ls swap on a chevelle, I'm getting to the fuel system, I have both fuel rails return and returnless, which one would you guys prefer to go with?? the returnless will have a corvette fuel filter near the fuel tank
Where did you obtain the quick connect fittings? When I built my '67 LS1 car, I had the hardest time finding new fittings, I gave up & had to scrounge good used fittings at pick-a-part.I’ve run return,ESA with the Corvette bypass filter on both my swapped Chevelles, one an LS and the other a DI V6. Pump and filter mounted in frame rail on pass side. No problems with either car.
