Relation between dieseling and timing
1 reading
23K views 8 replies 6 participants last post by  zeke67
Hi,
So my car has been dieseling when I shut it off. At first I thought it might have been old gas but I just refuelled it and it still does it. So I read there was a relation between dieseling and timing, but it seems to me that when you shut the car off, no matter whats the timing, there should be no more sparks anyway, so why is there a relation between the two? An explanation would be appreciated!
Thx
#3 ·
Dieseling or run on is the result of the fuel being used auto igniting .
In other words there is enough heat and air in the combustion area to light off the fuel being used.
Lower octane gas will ignite quicker or has a quicker flame speed or more BTU of energy and therefore will cause run on easier than higher octane.
But we also need air mixed with the gasoline to get this to make FUEL.
You do not need spark if the conditions are correct. as you know.
The cure is to kill the gasoline flow or air flow.
In the carburetor world killing the air is easier.
Closing the throttle plates kills air.
Too low of initial timing will make the engine idle low and will make a person raise idle speed by opening the throttle more.
Well opening the throttle more allows that air to get into the engine.
Higher initial timing will allow you to close the throttle more.
Screwing idle mix screws out to have higher idle will also allow you to back off he idle speed with the closing of throttle blades.
Sometimes heat is high enough or conditions are perfect to light off the mix with the smallest opening.
In this case I have installed a solenoid to set idle against.
When you turn off the key power drops out the solenoid and the throttle slams completely shut killing all air and the engine instantly dies.
Confused enough yet..
#4 ·
In 1971 Chevelles, This is how Chevrolet would stop 307 cars from Dieseling. ( Dieseling = Fuel in the combustion chamber is ignited by HEAT & COMPRESSION " Without the need of a spark.
71 owners may know this. Under the glove box you will find relays. What do they do? When you shut the 71 -307 Chevelle ingition " OFF " and pull the key out of the colum, LISTEN REAL CLOSE, WHY?
You will hear some " CLICKING NOISES " under the glove box,,,,GEE whats that? When the key is out and in your hand, This starts in motion the G.M. 1971 ANTI diesel system.
This is how it works- After the ignition is turned OFF, The key is in your hand, The relays apply 12 volts to the A/C clutch on the engine, Without the engine having any source of " Ignition power " The A/C compressor is now ENGAGED..... The A/C compressor is now trying to do its job by pumping R-12 Freon. With the compressor ENGAGED and trying to pump freon, This action or " Engine Load " will cause the engine to STOP rotating, And or " Dieseling ".
Another way to stop a car from " Dieseling ", TRUST ME this AINT the right way to do this, I have done it many times in my EARLY years with my one owner LS-5 .M-22. At the same time you shut the key off, DUMP the clutch in High Gear.
To avoid all of the above problems, Also the possibility of DESTROYING your engine, NO not hurting but, DESTROYING your engine. Get your Ducks in the right order.... Fuel - HI-Test or Cheeeeep Stuff,,Timing,,Compression,,Air Temp.,,Humidity,,Factory items missing from engine bay ( fan shroud, fan blade?-Etc., Etc.) Water temp.= engine bay heat?.
It is not Mission Impossible,, One or two items may be out of order, Get some help, Find a gearhead. Good Luck.
Bob
#5 ·
I never knew about the AC thing.. Pretty sneaky really.
My 78 nova had 245psi cranking pressure and this was checked with the throttle closed!
over 12.0 compression with iron heads 54cc chambers and 270H comp cam 224@.050
When I turned the key off it did not even act like I turned it off continued to run like normal.
This was with Sinclair 93 octane and back when the 91 and 93 was orange or pink in color.
It would also do it when I ran TEL in it or TEL and other boosters that make your hair fall out.
The solenoid was the only fix other than idling it down to 650 rpm.
And I do not like the low RPM idle.
Again the AC deal is a neat bit of information. Thanks Bob
#9 ·
Retarded timing will make an engine hotter at idle. Which can create these hotter spots in the combustion chamber that can aid in auto ignition. As cars got into the emission years of the 70's, to handle NOx creation which happens at higher cylinder temperature, timing got retarded. In addition to the AC relay trick, which is elegant, some cars use a solenoid on the throttle that would fully close the throttle blades with the ignition off.
