I have a 67 malibu that the whole back window was rotted out. I have hand made the window channel and replaced the trunk to window filler. There was none of the trim studs left and if there was I would have had to cut them out to replace the window channel. I have no idea what to do to replace the trim studs what should I use and how do I determin placement. I did the best job I could at matching the original angles in the channel but it is not perfect. I'm worried that even if I figure out how long the stud needs to be each stud will need to be a little different. I'm really out of my area of expertise here. any help would be awesome thanks.
Nathan
Nathan
