Getting my brakes finished up and running into an issue with the fitting size on the driver's side line. The proportioning valve I bought is linked below, new front brake lines for power disc from ss396(the right stuff) match the old ones currently on the car although the routing from the prop valve to the master cylinder will need some adjusting.
The issue is that the hole in the prop valve for the front drivers side is 3/8 and the fitting/nut on the driver's side line is 1/2 with the correct 3/8 on the hose side. Local parts store had adaptors to go from 1/2 to 7/16 then from 7/16 to 3/8 but I worry about stacking two adaptors and if the 3/8 line would seal well to the 1/2 adaptor.
Did I buy the wrong prop valve? Is there a correct line to buy with double 3/8 fittings instead of a whole new kit? Do I trust the two adaptors, or do I cut off the oversized fitting and put on a 3/8 fitting (never done before but shouldn't be too bad)? Any advice appreciated.
Prop valve: Proportioning Valve, Disc/Drum Brakes, Reproduction @ OPGI.com
