I was wondering what is the pro's and con's of plugging the by-pass on the spin-on oil filter adapter. I this a good thing to do to an engine that will see 98% of it's time on the street?
-Originally posted by Mike Feudo:
Every race motor I ever built had the filter bypass plugged. Every street motor I ever had had it operating the way the factory made it. In one of Jenkins books he states that even a smallblock requires the 2quart truck filter to flow enough oil at high RPM with the bypass plugged. I don't know of many street cars that have room for the big filter. It is just too easy to get into trouble with the bypass plugged.
This advice (and that of others that echo it) is all you need to know. I, too, have a blocked bypass and I use 5W-30 or 0W-30 synthetic oil and PF35L filters (they have synthetic filtering media, which works better with a blocked bypass). I always drive very gently until I see my oil pressure at the operating level at idle. There are other good oil filters out there, too. Do a search to find some of them.Originally posted by onovakind67:
I block the bypass. One shot of dirt in the bearings is more than I want. If one is contemplating blocking the bypass, you must also contemplate using good oil and a good filter, changing the oil regularly, and acting like you have blocked the bypass. Let the engine warm up thoroughly before you create high oil flow conditions.
K&N's with the big 1" nut on the bottom. Good filtering, high, high burst rating.Originally posted by Troy70SS:
I have been using the Fram HP4 racing filter and a blocked bypass. What's the opinion on the HP4? Can you suggest a better alternative?
Troy.
With What oil? 20w-50?Originally posted by Mike Feudo:
