I recently bought a "husky" brand (campbell hausfeld) air compressor from home depot. It is the 220v, 60 gal 3.2 running hp. I built a 220v extension cord using 15' of 10/3 wire to the 220 outlet by the fuse box. Now that I have this thing hooked up, everytime I let it run it will shut itself off at 60psi. I was expecting 120 or so? It will only come back on after you let it sit and hit the reset button on the electric motor.
Also, after it gets up to around 40 psi, it sounds like the electric motor starts cycling on and off. Is this something I can adjust, something I hooked up wrong, or is this faulty and I should take it back?
This is the one in CH trim: http://www.cpocampbellhausfeld.com/air_compressors/professional_air_compressors/vt6275.html
