Need valve spring recommendation...
2.4K views 11 replies 9 participants last post by  CNC BLOCKS N/E
I need a valve spring & retainer recommendation for a pair of Sportsman II 200cc heads I have on hand. I believe they will accommodate up to a 1.4X" dia spring as is and have standard length valve stems.
I'm building a mild, 9.5CR SBC 388" using a later model 1pc seal 350+.060 block that has the factory roller setup AND a mechanical fuel pump boss. :cool:
I will be using a new Reed hyd roller cam that I already have. Since Reed is gone I cannot call them directly for a recommendation.
Grind: 335-TM278HR-TM284HR-110A2 (Serial# M5548)
Year: 1987-1999
Running Duration: IN: 278.0 EX: 284.0
Lobe Lift: IN: 0.340" EX: .0340"
Valve Lift: IN: 0.510 EX: 0.510 w/1.5 rockers
Duration @ .050: IN: 226.0 EX 232.0
Lobe Center: 110
The cam card...
#4 ·
Bill, call Chris Straub.. he'll hook you up with a better spring than Comps, at probably a better price. :yes:
#6 · (Edited)
Those Torque masters were awsome lobes. The heads should be cut for a 1.260" or you can go with the 1.440" OD Dual. A super clean 1.260" on that lobe will be fine though.
Steve Demos is still around and grinding. He can answer any questions about that lobe. I useded it quite a bit in marine applications.
Chris,
I've been saving this cam for something special. Recently got a great deal on a pair of 64cc chamber 200cc Sportsman II heads and figured I'd run them thru the machine shop to clean up and a spring upgrade.
Just looking for a recommendation on a set of springs, retainers, and locks compatible with the specs outlined on this cam card shown above.
#5 ·
Does Demos have the masters for the Torque Master HR lobes? I really like the Reed Hyd FT I have in my 327 - wouldn't mind running Reed lobes on my current 350 HR build.
Hey BillsCamino... I am also using a 12cc dish in my 350. I chose the Speed Pro H815ACP hypers. These are Vortec replacements with the metric rings. Cheap way to get a modern thin ring pack in an old 350. Mine is still in the 'build phase' right now. The speed pro plasma moly rings are only $75 at Amazon, and Summit sells the pistons for ~$191.
#11 ·
the cam card wants 120-130 seat, 300 open at .510 lift. that would be about 350lbs/in rate, pretty light spring. the Comp 987-16 is real close to that, like 370, shim it a little, maybe 1.775 instead of 1.800. give a little extra to account for settling in after a few thousand miles. Or Chris probably has something better for less.
