Hey guys,
I need help here. I cannot figure out if I have the correct upper alternator bracket for my 66 chevelle. I am not running a 396 in it. I have a 454. I assume the mounting holes are the same for both engines. When I use the upper driver side bolt on the short water pump, the top bracket hole is off about 3/4" of a inch. Here is the link below for the bracket I bought off ebay. Will this bracket work on my 454? Also I am using a edelbrock torker intake manifold. Shouldnt all the upper alternator bolt locations be the same on all the manifolds?
http://www.ebay.com/itm/221027760533?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
