Captain Crunch,
I agree - hp numbers are meaningless - most people talk jet size rather than hp.
About NX being junk, I've had good luck with both NOS and NX solenoids - didn't experience the high amp draws you speak of.
One advantage to the NX kits is that they come with a high pressure tuneup - 8 to 10psi, which is easier to set than trying for 3-5psi with NOS.
I have three friends with gemini quad plates and I had one myself - they worked flawlessly with the supplied tuneups.
I think all the parts are basically the same from all the manufacturers, just different jetmaps and support for their products.
About the solenoids - NX has a new huge solenoids that draws very low amps - damn near the size of a beer can - interesting but expensive.
I now am a believer in sending your kit into a shop to have it flowed and mapped - I used Jeff Prock at Applied Nitrous Technology
www.appliednitrous.com and am very pleased with the result. He has a database of safe tuneups and real world results so he can get you close first time out. And his labour is cheaper than a set of pistons...
With his initial tuneup on my engine I picked up more than 400 at the tires on 93 octane and a fat tuneup - very consistent cylinder to cylinder.
66 283
