I am looking to buy a new carb and i'm not sure on which one I should get.
I was looking at summit new carbs but i'm still wondering if it is a good quality carb. I have been hearing good and bad things about summit products, and this is one has not been out long enough to really get any good reviews. I have two carbs now one thats an edlebrock 600, and one thats an holley 750 part#3110. Tried to rebuild both, but only made things worse. Been trying to get this car on the road for the last 3 months. What I would like to get is the holley 600, but I am a beginner and I am not comfortable with tuning a carb so I would like something that is easy to learn and tune right out off the box with minimal tuning or be able to make baby steps. I do want to bolt an go but be able to tune where I need it . This is on a budget, so I'm trying to not spend to much more money as it will only take me even longer to get it on the road. Who has started of like this and has been successful at tuning the holley 600? This will be a daily driver and I do have a fair amount of mechanical skills, just not with a carb. I have been to a couple of shops but they seem to be in buisness to just make money with no quality envolved.
this is what I have:
350 4blot main .030 bore
10/10 crank polished
speed pro forged pistons
bottom end balanced
.465/.488 Advertised Duration: 282 int./292 exh. Lobe Separation (degrees): 114
Duration at 050 inch Lift: 224 int./234 exh.
edelbrock rpm heads
1.5 aluminum roller rockers
edelbrock rpm intake
50,000 hei coil
th350 stage 2 shift kit 2400 stall
posi 12 bolt w/3.42
I don't race or anything but when I get in, I like to get in go.
Is a 600 good enough?
I was thinking if I go with the holley I would a good performance while driving to work and on the weekends.
I am willing to learn, but it took me 3 yrs to build this car with just manuals and magazines!
I just had the motor redone and I my current carbs are dumping to much gas and i don't want towash my rings.
Any advice would be appreciated!:thumbsup:
Also if you guys have any advice about my combo i'll take it!
thanks steve.
bottom end balanced
edelbrock rpm heads
50,000 hei coil
posi 12 bolt w/3.42
thanks steve.
