Muncie 4 speed?
1 reading
2.7K views 14 replies 9 participants last post by  DZAUTO
Hi everyone, I have a transmission I’m trying to identify. I think it’s a Muncie? Here are the numbers I was able to pull off of it. Thanks in advance for any help.
GM Patent # 3088336
3885010
3846429
#3 ·
I believe those are case casting numbers. There should be other numbers stamped vertically near the main case parting line.
#7 · (Edited)
GM Patent # 3088336
3885010
3846429
The 3885010 main case, as already mentioned, is a 66-67 ONLY Muncie main case.
The 3846429 tail housing -----------DEPENDING ON THE CAR-------------- could be 63-64 or EARLY-65 for a Chevrolet or Corvette (Chevrolet went to pass side speedo fitting in mid-65). BUUUUUUUUUUUT, some cars such as a Pontiac GTO used that tail housing up through 1970. Therefore, IF IT IS AN ORIGINAL, UNTOUCHED Muncie, then I would be willing to speculate it came out of a 66-67 Pontiac (a stamped date code will have the year), maybe a Lemans or GTO.
If you can locate a STAMPED VIN, and if it begins with a 1, then it came from a Chevy product. If it begins with a 2, it came from a Pontiac, 3 is Olds and 4 is Buick.
Here is a comparison of Muncie tail housing with the hole for the speedo fitting on the passenger side (left housing) and the driver side.
7 different versions
I had a 65 Chevelle Supersport in High School Graduated 75. This will give you an idea of the what you could buy then. Bought it from a neighbor for 120.00 with Bellhousing, Clutch and throwout bearing. Bought a Hurst Shifter for 30.00. Dropped a 396 with ported heads, 360hp Vette cam. I think it was a M21. Bracket Raced it with slicks and not a hiccup. Great Tranny! Just pound it shifting what I just don't feel you can do today?
#12 ·
Ok, I was able to get some more info on the transmission. I apologize, I forgot to say that it is in a 68 Chevelle, but it’s not the original tranny for that car. Here’s what I’ve got to add. The code on the passenger side rear of the tranny is P7B16. I believe that is Muncie Plant, 1967, Feb 16. There are 7 bolts on the drivers side casing. Also the input shaft has 10 splines with two notches in it.
#14 ·
1967 Muncie. There are other indicators to tell if it’s an m20 or m21. Such as one groove on input shaft = M21 and two grooves on input shaft is M20.
