Muffler size problems?
1.8K views 15 replies 4 participants last post by  driver
#1 · (Edited)
Trying to go from a 5 inch system down to a 3.5 system and has turned out to be more of a deal than I thought.Picked up my new muffers and called the local muffler shop and found out no one in the city can bend a 3.5 exhaust.It can be done at a local custom shop for a starting price of $1,000 big ones.I
need to know if it would make a big differance in HP between a 3.5 and a 3.inch exhaust.?? thanks,driver
#2 ·
Use mandrel bends and weld them together like you would making custom headers. Local muffler shop benders will kink or undercut the back side of the bend where it follows the shoe. I doubt any shop would have an expensive mandrel bender...maybe, but somehow doubt it. They are usually used by manufacturers doing high volume stuff.
How about doing an X-pipe like a Dr. Gas kit? That would give you all the pipe & bends to get from the headers to the mufflers.
#3 ·
Same thing the custom shop said today.I can't see putting $1,300-$1,500 IN A EXHAUST.Im no welder so that limits my choices.I know they can do a 3 inch and if there isn't to much difference between the 3.5 and 3 inch in hp I will go that way.It's becoming a pain in the rear.
#9 ·
One more question? Did you do the welding on your system and if so what type of welder did you use?Instead of giving a custom shop a grand maybe I should invest in a welder and learn to weld myself.Im sure I'll get plenty of use out of a welder over time which will pay for it's self.That's if I can teach myself.
#10 ·
Yes, the Dr. Gas system requires the joints to be welded, but it's fairly easy with experience.
I originally welded it together with a Mig machine, but this last time around I rully Tig welded it for a cleaner, neater appearance.
The tubing is 16 gauge wall thickness aluminized, so some grinding of the surface at the welding points makes welding much easier. It's also a good idea to clean the inside of the tubes out prior to fabrication & welding as the mandrel bender leaves a grease film inside the tubing.
#14 ·
Driver,
I built my 3.5" system myself using 3.5" - 45 deg. mandrel bends and straight pipe and pieced them together and then welded them. I have a MIG and TIG welder, but was in a hurry (3 AM trying to make a race)so I just MIG welded it to save time.
You might check with a local welding shop on getting a price just to weld up the pieces after you fit them to the car. You would just need to fit and clearly mark how the pieces should be oriented. I would think that you should be able to find a shop that would do it for a couple hundred bucks. You will need to be sure you fit the joints nice and tight.
You should be able to get 3.5" - 45 and 90 degree bends from any truck shop that sells class 8 truck parts
Save
#16 · (Edited)
Well I went out today and bought a LINCOLN MIG WELDER 135 amp.Now learn how to weld!! HAHA.Wasn't cheap but it's a good brand name so it should last for years to come.I did some welding on used junk stuff which I did ok but no where near good enough to weld on my exhaust.Any pointers on mig welding would really be helpful.Thanks,Bill
