Not in a Chevelle, but my C10. Swapped in a truck 5.3, factory 862 heads, with a Sloppy Stage 2 cam. 585 lift, 228 @ 50. Stock intake and throttle body. Th400 and 373 gears. Running it with Holley Terminator X. Ran it with manifolds for a long time and took it to a dyno to be tuned. Last week switched to long tubes and quieter mufflers. Picked up a lot of grunt from 3000-5000rpm. Was averaging 13mpg when cruising at 60mph with little traffic. My commute has more traffic these days and speeds vary, and my mpg is closer to 10-12mpg. Was hoping headers would help out, but they haven't. I put a couple hundred miles on it this week and transferred over fuel learn table to the base table a couple times to adjust for the headers, and that's gone well. But there must be a way to get fuel efficiency better.
Has anyone put honest effort into tuning for cruise mileage? Initial tune had timing at 36 degrees at WOT, and the same at cruise. Shouldn't cruise want more timing to deal with the lower load? The big block in my Chevelle had cruise timing in the low 50s and ate it up. Cruise AFR is at 14.7, could I get away with 15.0, or higher?
