http://store.summitracing.com/partdetail.asp?part=NAL-12568782&autoview=sku
Gen VI 502 short block, with hydraulic roller cam and provision for mechanical fuel pump.
Per Summit: "The cam has 0.527 in. of intake lift and 0.544 exhaust lift, with 110 degrees of lobe separation. Duration at 0.050 in. of lift is 224 degrees for the intakes, and 234 for the exhausts."
#1 - I thought short blocks did NOT come with a cam-
#2 - how would this combo, if it does work out that way, work using my cast iron heads, enlarged valves, with 107cc combustion chambers due to unshrouding?
Any thoughts welcome - I'm trying to keep the budget under control on this one, and was planning on using everything I could off my 402.
