So finally after a lot of reading/researching decided to upgrade to the jeep box. I had the day off from work but drove down and did it there so I could use the lifts, work benches, and the other unlimited resources a shop offers. Got a rebuilt jeep box from Autozone, rag join #200 from Advance auto, and Lee's hose adapters. All in all about $150.
First I used white out to mark the center/up position of the steering column where it attaches to the rag joint. Then drained the PS fluid and lines from the box.
Next I removed the bottom bolts of the St. box. I just loosend the top bolt so I could use it to swing upwards when removing the Pitman arm from the spline.
One needs to be replaced...
Removed the castle nut from the center link and nut from the pitman arm spindle. The nut for the pitman arm came off rather easily, but then again I was using a 3' 1/2" breaker bar
Using the pitman arm puller first I was able to separate it from the spline. After I swung the box upward and propped it up out of the way, this left me room to put the ball joint puller in there and pop that sucker loose. After that it was just the last bolt on the box, and she popped right out...
Something here seems out of place...
Work station...
Work station...
