I have a 1969 Chevelle that is currently in the middle of a frame off resto. The body is still off the frame and I have the engine and Trans (454 & TKO 5 spd.) sitting in the frame. I am having some location issues with my tail shaft mount on my cross member. I have already cut the tail shaft to make room for the cross member since the TKO will hit. The issue is that the tail shaft is not centered in the frame. The car was hit on the front driver’s side, but has been pulled, straightened, dipped, and powder coated. I’m not 100% sure what the issue could be. I’m thinking that my frame motor mounts need to be loosened and adjusted or that my cross member is bent. I didn’t send the cross member with the frame to have it straightened. I am hoping that someone on here has run into this issue or that it’s normal. I know some cars don't have a centered power train. I really hope that I don't have to mess up that fresh powder coat. I have pictures of the measurements from the center of the tail shaft to the outside of the frame rails. Any thoughts or comments would be greatly appreciated!
Thank you in advance,
Christian
Christian
