Yes Gene,with that comp cam approx 18 initial is where you should be,if the motor is detonating with only 5 deg initial & 93 fuel something is wrong.
Is it possible you have a lot more compression then you think or the motor is all carboned up increasing the compression?
Possibly the outter ring on the harmonic ballencer has slipped and its not giving you correct timing #'s?
The motor should run like a slug being approx 13 deg retarded on the inital timing not to mention running hotter too due to the overly retarded initial timing.
You need to verify that the harm ballencer & the timing tab on timing cover are ok/correct/accurate. If you dont find any issues with thoses items then you may need to verify if the new cam you installed a while back was lined up correctly .
The cam you have is only 224 deg dur @.05 ,i am running 222 deg dur @.05 in 50 cubes less motor with 9:8 comp and it has high cyl pressure with oner 200psi static cranking compression. Just for ha ha's take a comp test a couple cyls to see what it is,if your cranking compression is over 9:0 it should be pretty high with that mild cam. Make sure to disable the ign and hold primary & secondary wide open with taking the comp test. If you have readings of approx 180-200+psi your cam timing is short for compression being run causing high cyl pressure and you would simply need to install more cam to bleed off some cyl pressure. The comp test is not a great indicator of comp ratio but it gives you an idea if you do in fact have high static cranking comp so chk a couple cyl's & let us know what you find out. you basically running the same cam in a motor 54 cubes larger and can cause higher cyl pressures leading to detonation which i have been warning people about choosing too mild of cams for todays crap fuel to handle since my experience. I used the cam that my machinest & others rec just to find out i was correct in not aggreeing with them and should have listened to mytself and installed a little more cam but i listened to the experienced machinest and got burned with 200psi + cranking comp/not pump gas friendly.
Scott
Scott,
I re-checked my initial timing last night and it was actually closer to 6 degrees BTDC. I can't stress enough about how hard it is to se my timing scale. When my engine was disassembled I cleaned all of the carbon from the cylinder heads so I don't think that is the problem. The pistons are simple flat-tops and the stroke is also stock so I am inclined to believe the factory compression ratio of 9:1.
I suppose it's possible for the balancer to have slipped leading to faulty ignition timing numbers. I may have to order/make a piston stop to verify the balancer's relative position to the timing scale. Though I'm not 100 percent sure, I think the timing tab/scale was spot welded to the timing chain cover from the factory, therefore it would be impossible for the timing tab to have moved. However, I am going to check the balancer and the scale in order to verify all is well in that department. The camshaft was "degreed-in" and checked and double checked by a competent engine builder so I don't think there's a problem there either.
Before the engine was dissassembled I had no cooling issues what so ever. Now after the block was cleaned and the radiator was re-cored the engine does want to run hotter (up to 210 degrees) than ever so there is some issue there. Now I'm wondering if the 12 degrees of retarded timing itself is increasing my engine temperature and therefore causing the engine to detonate?
I will perform a compression test as you instruct to check for high cylinder pressures. In the meantime here are my timing numbers taken last night:
Initial timing: 6 degrees
Initial timing with advance connected: 32 degrees
Total timing with advance disconnected: 32 degrees +/- at 2,900 r.p.m.
Total timing with advance connected: approximately 43 degrees (I ran out of timing tape at 40 degrees) at 2,900 r.p.m.
Again I want to thank you for all of your help. I'm going to do some additional checking and testing and I'll post my findings.
Thanks again,
Gene
Here's a visual:
