Hello Fellas,
I am trying to get my 468 to idle (with the vac guage on) and it does not want to happen.
I am thinking it is a vacuum leak but perhaps it is the carb. The carb is a 750 double pumper.
I CAN get it to idle and am able to set the timing at 12 degress when I unhook the manifold vacuum port. I heard that this speeds up the idle but obviously I need the vac for my modulator and brakes.
Here is what I tried.
1. Put duct tape over valve cover holes (pvc and breather). Pushes out tape a bit. Does not suck tape in.
2.Removed heat shield from under carb suspecting a leak. Installed carb right on manifold. No change. Also tightened down carb bolts (not too much to avoid cracking baseplate)
3.Put rag over top of carb while running. No change.
4.Tightened all manifold bolts.
5.Turned idle screws counter clockwise 2 turns. It is probably really rich now.
6. At 2000 rpm vac guage reading is 10 pounds and at 1000 vac is 5 rpm.
I heard a what sounded like a huge hissing sound coming the ventri area of the carb. Is this normal. I tried to pin point the location using a rubber hose as a listening device, but I need a assistant. Should I focus my attention in the carb area. If so is there a typical area that it would leak.
Thanks in advance,
Kris
Thanks in advance,
Kris
