I put in a new Powermaster high torque mini starter and was wondering if it needs a shim. Right now there is no shim in it. First i tried it with one shim, and it sounded smooth when starting, but it would randomly sound like its just spinning and missing the teeth on the flywheel.
So I decided to try it without a shim, and it sounds like the starter cranks a little slower than it did with a shim. Also the first time I tried starting it after I put it in with NO shim, it make a loud clunking noise, then has been cranking normal since.
