1 - 10 of 10 Posts
Non egr is for a car without one, some states have laws about polution so you may not be able to use it....everyone does anyway. And if there is anything other than a heat riser attached to the intake or air cleaner then you have one. It will be a round attachment on the neck of the intake manifold.
Discussion starter · #3 ·
So if my car does have one, I can still get the carb with no EGR? I don't care about my state because we don't require stickers on antique autos.
Sent from AutoGuide.com Free App
I'll stick my neck out on this one. So far as I can recall no Chevelle up to and including but not past 72 ever had an EGR valve.
Where there was an heat riser it was to warm up the carburetor to aid in the atomization of fuel when the ambient temperature dropped. Past 1972 I have no clue nor do I wish to remember...being retired and all.....
i'm pretty sure every small block and big block had EGR valves by 1973. properly functioning, it's actually a good thing that can help you live with too much compression with crappy gas since it dillutes the incoming air/fuel mixture with exhaust gasses under part throttle conditions, which can keep it from detonating... but they never work properly for very long, so it's best to just get rid of it and block it off..
regarding the carb: it's an aftermarket non emissions compliant part, so they have to put that disclaimer there..
Back in the day I had many cars come into my shop with the complaint that the car was pinging. A test drive always confirmed that the customer was hearing correctly. Typically I would find an 1/8" BB inserted in the vacuum hose to the EGR valve. Removing that BB would instantly cure the ping issue. Friendly mechanics were doing that as a favor to their customers who hated those government mandated pollution devices.
This was common in the late 70's. In those early years when the manufacturers were trying to deal with the pollution edicts from our benevolent government they developed the EGR to help the engines then being manufactured deal with the ever leaner fuel air mixtures.
For all practical purposes an engines exhaust gas can be considered an "inert gas", meaning it will not support combustion. The EGR ports a bit of that exhaust gas into the intake stream so as to "cool" the combustion process, which was leaner and hotter than in earlier non-epa years, and eliminate the characteristic ping that came along with those leaner mixtures.
Additionally, as the years went on the EGR and its associated exhaust passage would become clogged with carbon deposits and cease to function even though the valve itself was still functional. Cleaning out the exhaust passage and the EGR valve with a pick and a vacuum cleaner would get rid of the ping once again.
Sorry for the newbie question but how can I tell if my 72 has an EGR valve? The reason I ask is I'm looking at the Edelbrock 1406 600 CFM carburetor and it says non EGR? Does that mean it eliminates it or is for cars that are not equipped with an EGR valve?
Why not google egr valve and look at some pics, then look at the engine to see if one's there?
1 - 10 of 10 Posts
