I'm getting closer to starting the 427 for the first time. It is a roughly 10:1 427 with an Ultradyne 276/284 cam installed 6 degrees advanced, heavily massaged 049 heads with 2.19/1.88 valves and a Holley 3310 rated at 780cfm on a Chevy aluminum intake, (looks almost exactly like a Edelbrock Performer RPM with 1/2" shorter plenum). The Holley is a stock replacement for the 425hp 396 and 427s. It has 70 jets in the front. For the first firing I'd like to have it running just a touch rich to keep the temps down a bit, I certainly don't want it running lean.
How can I determine what jetting would be appropriate for the initial firing?
Can't wait to hear this thing cackle for the first time!
