You will get the best results if you seek up on the trim mark, you don't want to try it nail it the first go around. You will also get the best results if you use tin snips to make the final cuts.
Another benefit of the tin snips, as told by a sheet metal master, is that the snips stretch the metal out on the cut line. As you weld the metal shrinks, by having the metal pre-stretched, although a tiny bit, the distortion is less.
Never understood the buttweld clamps that Eastwoods sell, and yes I have some. More often then not, the gap left by those clamps .040, is wider then the thickness of the metal you are welding. Companies like Eastwoods spread this notion that you NEED a gap when welding sheet metal then creates the solution, a product that produces the PERFECT GAP.
F*ck what a load of crap.
These clamps create more work, a gap of .040 is far harder to weld shut then a no gap joint.
If you are covering your weld joint with filler then you have distortion. Sorry but you CAN NOT weld and NOT get distortion. Several things effect distortion. Gap, heat exposure and cooling rate. If you are welding with a MIG, then you have no control over two of the three, you only have control of one and that is gap. The less gap you have the less distortion you get.
A few tricks can be made to make those clamps better. Trick one, swap out .040 piece of metal for a thinner one. I've seen a few done with metal banding material, and some with razor blades! Trick two, mark out the location you plan on installing the clamps and make a notch on one of the pieces of metal wide enough for the clamp. The notch recesses the clamps.
Now when you hang your panels you have a no gap to little gap across the entire seem, the only gap you would have to weld is the notches you made.
If someone wants to change their method or not change or commit suicide, frankly I don't care. Just trying to post factual information and not some crappy Eastwood propaganda. The time spent getting a no gap to little gap is not that much more time, but saves time during welding and post welding prep...Eric
