So....was having a stalling problem since converting to locked out distributor and enabling timing control...did this 3 days ago, and finally drove the car yesterday...
Acts as if the power is being interrupted, for a split second, and intermittently stalls.
Runs fine (or seems to) at higher rpms, and has no issue revving to 6000 or so...
If it stalls, it seems to be flooded on restart...have to hold gas pedal down to restart...
If it flutters, but doesn't stall, a red light pops on in upper right corner of handheld and car immediately goes into open loop, and higher idle, for a few seconds....like if it was just re-started?
All wiring connections have been double/triple checked....I mean there's only 2 wiring changes, and plugging in a harness in one spot, or the other...
I even installed a brand new MSD Blaster SS coil, which made absolutely no change.
Distributor and timing control setup was done exactly how this Holley video said to do it:
https://youtu.be/S2zfmemVKQE
However, this video seems quite a bit different??? Concentrates more on the phasing, and also is a bit different in how they verified timing numbers matched...NOTE: I did NOT use this video for reference, but wonder now, if I should have??
https://youtu.be/owUHU1tPw68
Looking at this 2nd video, I know I did not verify timing, other than the static check as per the Holley video. Maybe I should have set timing at all 3 parameters, the same and verified it matched the balancer?? I don't think that was the issue though as it ran great, then would just randomly, with no pattern whatsoever, die...
As a test, I switched the timing back to conventional, with the Holley just running the fueling...
So to do that, I disconnected the white wire from the 10 pin Holley harness, to the MSD DIGITAL 6AL box (#6425) points trigger (also a white wire).
I also unplugged the 2 wire(purple/green) harness from the 7 pin Holley harness and MSD distributor.
Re-connected the single purple wire back to the MSD's gray tach, or "trigger" wire.
Re-connected 2 wire (purple/green) harness to the MSD box, and MSD distributor.
Swapped back on the non-adjustable rotor and made the tune change back (via the handheld) to CD ignition box as the ignition source.
Since timing is now locked, I started car and set timing to my chosen 44* and car is back to running great again...
No flutters, no stalls, no issues whatsoever...
This really sucks, since I wanted to have the Holley ECM control my car's timing, and in the near future, my nitrous activation...
If I wasn't planning to run nitrous next year, I'd honestly not worry about the timing control, but for now it seems, I have an option, that is non-functional... :frown2:
Any ideas, suggestions, would be appreciated.
