Ok,
If you read my other post you know that I took apart my 350. The heads that came off the motor are sportsman II's with low mileage(less than 10'000). I did a leakdown check prior to pulling them off and all was well with the valves.
All in all they seem to be in great shape except for one thing. There is a bunch of carbon built up on the back side of the intake valves. I was hopeing to reuse then "as is" but the carbon bothers me.
Am I worrying about nothing? Should I disassemble them and get everything tanked? If I get them tanked, does that generate some machine work to reseat the valves.?
Also, I have what appears to be Teflon PC seals. How many times can you remove and replace a valve before you wear out the seal?
Clark
Clark
