Looking for some help/advice.
Going with a full manual shift 4L80 and a 10" triple disk converter (wanted WOT lock up capability) and want to use a steering wheel mounted push button switch.
My idea of what I want (other opinions welcome):
- Momentary on push button activated & deactivated (using a transbrake button)
- Brake light circuit deactivated
Looking for a way to lock/unlock with a push button with a brake activated unlock. Don't want to have to reset the process with a on/off toggle or other device.
Is there a latching relay that the momentary switch will toggle regardless it's current on/off state? This may be the easy part if I can find the right relay...
Then there needs to be a way to unlock with brake application (but not just toggle the relay or it would then lock if it were unlocked before the brake was applied).
Hope I got the idea described/outlined.
Thanks in advance
Allen
Thanks in advance
Allen
