Just got it done after work today. I used the MSD external coil HEI dust cover(PN 8401)
it does come with the necessary wiring,and Its all plug and play, so if you had to go back....you can without any re-wiring.
I ended up using the Crane PS60 oil filled coil. I read some real good reviews about both performance and reliability. Plus, after confirming on here with the rep from crane, and another source in house that these coils are in fact 100% produced in the USA.....I figured this was a good opportunity to support both USA made goods, and a company thats been through hard times but still trying to produce the same quality products as always for us.
Initial impressions are good. It starts easier than ever. Idle quality is better, and it actually seems to smell a little cleaner.
Tomorrow will be the test. I actually warmed the motor up before changing out the ignition parts. My carb is chokeless(holley HP), and it doesnt like to idle right off the bat when the motor is cold. Once it has just a little heat in it...it starts and idles easy. I figured if I made a mistake wiring, or if anything at all was wrong, Id know right away. Since I warmed it a little...it was either gonna start right up after the swap, or it wouldnt. It definitely started right up. Once its warm it usually needs to roll 2 or 3 times on the starter before firing. Now...soon as the starter hits it starts. I can reach in through the window and just touch the key, which is nice. We'll see what its like in cooler weather with the motor cold tomorrow though. I expect good things from what Ive seen though.
FYI Im not using an ignition box. Im just using an original GM 990 module to fire the coil. So...a box isnt needed for this setup.
