I'm looking at buying a used GM Crate engine 350 290 HP, does anyone know if GM breaks in the flat tappet cams at the factory in Mexico?
I'm looking at buying this 290HP 350 apparently has 3500 miles on the engine, I asked the owner if he broke in the cam and he said he bought the truck with the engine already in it. I asked him what oil he used and he said he did not change the oil since he's owned it, he said he had to adjust the valves (which worries me).
The engine is no longer in the truck as the owner has gone LS engine. The engine is on stand.
How could I verify if none of the camshaft / lifters are worn or going?
Could I hook up the starter and turn the engine over while I mark each push rod to verify each push rod is spinning?
I was going to cut open the GM oil filter to see if there is any metal?
What are your thoughts?
Thanks
Thanks
