I'm thinking about building some sort of a panel to mount all my gauges in. I'm using the following Auto Meter Sport Comp gauges (I think they are 2-5/8"):
- Water temp
- Voltage
- Oil pressure
- Trans temp
- Fuel Pressure
I'm also going to be installing a vacuum gauge in the car. The vacuum gauge is smaller in diameter (2-1/16" I believe).
I was curious to see/hear what some of you have done for gauge panels (pictures would be great). While the after market dashes (Dakota, Covan, etc...) are nifty, they are not for me. Previously I had my gauges mounted under the dash (water temp, oil, and voltage in a 3 pod autometer and the fuel pressure and trans temp mounted separately). The 2-5/8" gauges are pretty easy to read, and I don't mind the gauges being under the dash.
Thanks for sharing any ideas you might have.
- Water temp
- Voltage
- Oil pressure
- Trans temp
- Fuel Pressure
